Eurosec CPX - tamper reset??
25 May 2008
Nottinghamshire
I have a Eurosec CPX which is causing some grief!
We were doing some decorating and one of the wireless PIR's got knocked - this caused the alarm to go off unexpectedly (quite a fright!)
When I entered the unset code the alarm silenced but now when I set the system it goes off after 30 seconds even if no one is in any of the areas covered which I assume means I need to do a reset of some sort.
My installer is no longer in business and most local companies dont seem to want to touch it with a bargepole or are quoting £200 + VAT to sort it but I managed to get a copy of the Engineers Programming Guide from the manufacturer and have done a reset of the engineer code by disconnecting the power etc as I obviously didn't know what it was set to.
Is it an engineer reset what I need to do? There is another section in the programming guide under "programming reset modes" which refers to an option for "Tamper Reset = Eng + Anti" and I am not sure if maybe that is it?
Once I get that sorted, I also would like to add a new PIR to a new room - can anyone point me in the direction of where I can get one and give any guidance on how to add it to the system?
Jase
How did u do a reset of an engineer code? Cause disconnecting the power is not enough.
Thanx.
