DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
conservatory wiring
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
thirlmere
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 31, 2005 4:13 pm    Post Subject:
conservatory wiring
Reply with quote Thanks
is it ok to extend my ring main from exsisting wall double socket,put 3-4 more sockets and then spur off and put a 5 amp fuse box and then add lighting off that circuit. think its ok just need some advice
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Mar 31, 2005 5:23 pm    Post Subject:
How do you plan to extend the ring from one socket? Will you be able to replace the existing cable going to the next socket, or are you planning to join the cables somehow?
Assuming that's not an issue, then provided the floor area served by the ring does not exceed 100mē, and provided you aren't adding sockets in what Part P of the building regulations defines as a special location, and provided you test the circuit afterwards, then it will be OK.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 31, 2005 10:36 pm    Post Subject:
do it like this
except make one of the sockets the switch fuse that controls the lights.
Make sure cabling follows lines of least surprise (see reference section for permitted routes), or use conduit or armourclad if you really cant.
Come back if this makes no sense.
__________________
regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs-
Back to top
 Alert Moderators
brumtrician
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 01, 2005 9:49 pm    Post Subject:
when i do conservtorys i run my new ring around the conservatory with a switched fused spur in the circuit for the light/fanlight switch with a 3amp fuse in it. Then the 2 ends of this ring i put into the back of socket on the existing ring you want to extend. I leave one end of the existing ringmain and add one end of the new ringmain into the socket screw teminals then the 2 legs left i join with crimps and put heatshrink over them and leave them in the back of the socket box. Have only done this on double sockets so not sure if there would be enough room in a single socket backbox.
Just make sure you use a decent pair of rachet crimpers and not those cheap nasty things like plyers
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 02, 2005 2:45 am    Post Subject:
Conservatory
Ask yourself what your using it for. Electric heaters ? a no no. Lighting and low powered objects should be fine, but recommend you put everything used on the circuit you intend to use the clamp it to see how much power your drawing. Then decide
Back to top
 Alert Moderators
thirlmere
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 02, 2005 3:28 pm    Post Subject:
thanks guys thats a great help i notice one of you chaps said not to run electric heater off this idea i am looking to put a heater in how should i wire that in to.
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 04, 2005 10:35 pm    Post Subject:
heaters
Once again depends on loads already drawn and expected loads required. What sort of heater and rating are you proposing.
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 04, 2005 11:59 pm    Post Subject:
For almost all loads follow the scheme in the figure I posted, and loop into the house ring. Good for most situations. (Or if you really want to push the boat out then run a dedicated 30A 4mm radial from a new way in the fuseboard.)
For less than 13A total ever, put the whole conservatory on a fused spur.
Just add up the wattages of what you think want all on at once, and you will be able to see what you need to wire up..
__________________
regards Mike(G7VZY)
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wiring up a new conservatory (again) 3 1160 Mon Nov 21, 2005 8:07 am
conservatory wiring 5 480 Fri Sep 28, 2007 11:02 am
Wiring in new lights to a conservatory 2 560 Mon Oct 24, 2005 4:44 pm
Conservatory Wiring 12 700 Wed Jan 30, 2008 4:11 pm
Conservatory Wiring 2 660 Wed Oct 11, 2006 7:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
