DIYnot
Local | Network
   DIYnot > Forums
Local | Network
plumbing and heating: wire a towerstat rf into my ideal isar
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
alfieboy1
from United Kingdom
PostPosted: Tue Aug 17, 2010 3:40 pm Reply with quote
Hi I wonder if anyone can help im trying to wire a towerstat rf into my ideal isar HE 24 on the boiler wiring I have a 5 core cable BLU BROWN BLK GREY & EARTH THE BLK AND GREY are not connected and there is a link wire between the 2 terminals marked L1 & L2 the BROWN is wired into L3 Earth into Earth and BLU into N on the back of the stat I have a N & L & NO & NC and a COMM for 230v wiring it looks like you put a link between L & COMM N to N can anyone tell me what L1 and L2 are and in what order are they SL on or SL off as note to sure what gos where
Regards Alfieboy1
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 1056 times
PostPosted: Tue Aug 17, 2010 4:38 pm Reply with quote
There are to ways you can wire this.
1. Link L to Common at the Stat and connect NC (SL ON) to L2
2. Connect Common to L1 and NC (SL ON) to L2
In both cases, there must be a supply to L and N of the Stat; and the link must be removed between L1 and L2
Back to top
 Alert Moderators
alfieboy1
from United Kingdom
PostPosted: Tue Aug 17, 2010 5:43 pm Reply with quote
Hi thanks for promp reply so there is no need for the L1 to be used I did try it this way with just a switched live and got no heating when called for on stat got the fan blade symbol come up but no heating i did wire a honeywell stat between L1 and L2 and that works fine but that was only on a fly lead
Regards Alfieboy1
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 1056 times
PostPosted: Tue Aug 17, 2010 6:39 pm Reply with quote
Have you checked that the two parts of the Towerstat talk to each other?
First check the RF addresses are the same (page 7 - RF Address Code setting)), then check communication between the two parts (page 17 - testing RF transmission range).
Do you have a multimeter? If so you can check the voltages.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Towerstat RS vs. Honeywell Wiring Centre; wire colours 2 640 Thu Apr 08, 2010 10:29 pm
my towerstat rf won't switch boiler off so heating on full! 6 140 Tue Dec 24, 2013 10:12 am
Towerstat rf 11 960 Thu Dec 10, 2009 8:19 pm
Adding Towerstat RF Thermostat to Boiler. 6 320 Sat Nov 06, 2010 3:36 pm
Towerstat RF problem 4 1580 Wed Oct 28, 2009 1:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
