- Joined
- 17 Aug 2010
- Messages
- 5
- Reaction score
- 0
- Country
I hope that someone can help. The first garage to my house has power, with its own consumer unit, with a 100amp main switch, and spare MCB slots. I can completely isolate this consumer unit at the main board, where's there's an RCD for it.
The second garage is a few metres away from the first one, and I wish to provide this too with power (six double sockets on a ring main), and light (a couple of strip lights on one switch; and a small strip light in a telephone box outside the second garage on a separate outdoor switch).
I already have a lot of 10mm2 twin core armored cable, so would like to make use of this, partly to save cost, and partly as my house is built on solid rock, so trenching is next to impossible. I've thus bought a garage consumer unit, with a 32amp MCB for the sockets, a 6amp MCB for the lighting (I plan on wiring both lighting circuits to the one MCB), and a 63amp RCCB.
My thinking is that I can wire the new circuits to the second garage consumer unit, then connect this with the armoured cable to the larger consumer unit (once isolated) in the first garage, with a suitable (40 or 63amp?) MCB. By doing so, I can avoid having to meddle with the main board.
But I have a problem as to earth. The armoured cable earth is in the form of its steel sheath, so I've bought a suitable gland. But the second garage consumer box is plastic! How do I connect the earth of the armoured cable to the earth block in the second garage consumer unit?!
Additional questions:
a) Am I right in thinking that the line and neutral of the armoured cable from the consumer unit of the first garage should be connected to the 'Line' terminals of the RCCB, numbered 1 and 3? If so, which to which?
b) On both the neutral block and the earth block of the second garage consumer unit, terminal 2 in each case has no screw head. Why is this?
c) There is a busbar from the terminal marked 4 on the load side of the RCCB to the bottom of both the MCBs. This bar has a protective plastic strip over it. Should I remove this?
d) Am I right in thinking that I should connect the line phase of each of the circuits to the top terminals of the MCBs, and the neutral phase of each to the neutral block?
e) On the neutral block, one of the terminals (4) has connected to it a thick cable that runs to the 2 terminal on the load side of the RCCB. That leaves terminals 3, 1 and N free on the neutral block (2 has no screw head). Does it matter which of these I use for the neutral phases of the circuits?
f) Finally, the telephone box is a cast iron K6 red box. Should I separately earth this direct to ground with a stake, or in some other way? It will have in it the light connected to the new garage consumer unit, and a working phone.
Sorry for all the questions, but am very keen to learn. Many thanks.
