DIYnot
Local | Network
   DIYnot > Forums
Local | Network
baxi solo 2 faults
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
crush
from United Kingdom
PostPosted: Sun Apr 03, 2005 10:56 pm Reply with quote
I have a Baxi Solo 2 PF which has the following faults ,firstly about 5 times a day, the boiler fails to cut in ,to overcome
this i have to turn the boiler control to 0 wait 10 seconds and turn it to normal position, heating engineer said the fan was jammed up and replaced it,this worked ok for a week then started playing up again, and the expansion tank has started bubbling hot water and banging (system has been bleed),the pump also now stays on 24 hours, even with the heating and hot water off, has anyone any advice please icon_lol.gif
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2224 times
PostPosted: Mon Apr 04, 2005 1:42 pm Reply with quote
The pump should not stay on without demand. It sounds like overheating. Could be lack of flow (faulty pump) or scaling. Probably also a lot of dirt in the system which would require a powerflush. Open vent systems like the one you have are really quite outdated. To get rid of your problems once and for all, the best thing to do is to upgrade your system to a sealed and pressurised system like Worcester or Vaillant and have the works done by a known, local company. Added benefit is that you can drink the water from every tap in the house without the danger or unacceptable levels of bacteria in summer.
Back to top
 Alert Moderators
corgigazza
from United Kingdom
Thanked: 247 times
PostPosted: Mon Apr 04, 2005 4:14 pm Reply with quote
May have faulty 2 port vave with micro switch jammed, allowing boiler to run constant
Back to top
 Alert Moderators
Shand
from United Kingdom
PostPosted: Tue Feb 20, 2007 4:27 pm Reply with quote
I'm not sure if my problem is related:
I rent a place in Bath, a high limescale area. I'm not sure if that is relevant.
Our heating works fine, most of the time, apart from exorbitant gas bills despite the fact we have the heating on very rarely (as I type this I have three jumpers on, as usual in this damned fridge of a house). This isn't the immediate problem, although it would interesting to know if a technical fault could somehow boost our gas usage.
We have a Baxi Solo 40PF. The "Overheat" light won't turn off, no matter how long we leave the boiler either switched off at the mains or set to zero. The boiler doesn't even attempt to heat up, though, when we set the dial to a non-zero number, so how can it be overheating? It's probably about 15 degrees in there!
Thanks if you can give any information.
_________________________________
Lynda, moderator
Please note forum rule 20.
The replies you did get requested more information
Back to top
 Alert Moderators
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi 105e Fan Flue Failure and other faults 20 360 Sun Mar 13, 2011 8:59 pm
baxi 105 he instant led faults 8 300 Fri Sep 24, 2010 2:35 pm
Gledhill Boilermate 2 upgrading electrics after faults 3 240 Mon Apr 27, 2009 11:55 am
worcester cd30 - no central heating - no faults indicated 3 340 Thu Jul 09, 2009 9:50 pm
BOILER FAULTS 2 300 Mon Feb 23, 2009 9:19 pm
DIYnot
