Firstly, please accept my apologies if this has been covered before, I couldn't find the answer when searching.
In my flat I have two lights in the bedroom. Both are simple roses and I (well, the missus!) wanted to change them to better fittings. I bought two light fittings to replace them, a simple job or so I thought, I have done it many times before.
After fitting one of the the lights however the circuit breaker for that lighting circuit tripped as soon as the light was turned on. The new light fittings have metal parts and require earthing, unlike the roses. I have pinned the problem down to the earth wire, without it connected everything is fine, with it connected the trip goes immediately. I thought the fitting was faulty so tried the other one, exactly the same problem.
I then put a multimeter across the wires coming from the light fittings. All seems fine, in particular the earth wires (there are two in each light) do not seem to be connected to the live or neutral ones.
I then tried the other ceiling rose with exactly the same results, with both light fittings.
What's going on? Am I missing something obvious? Surely both fittings can't be faulty? And if so, wouldn't I be able to detect a short circuit with the multimeter?
Any advice would be most appreciated, as I am stuck with two unused light fittings and a missus who is certain I have broken something!
