Need some advise as this is new territory to me.
Working in an engineering firm today and at 5pm the laser cutter stops and so do a few other bits of kit. Traced to loss of a phase due to the main service head fuse blown, each phase is fused at 100 amp. Owner call DNO who will send someone tomorrow. It transpires that this happened 2 months ago, same fuse. Tails extremely warm and fuseholder too hot to hold. Removed a fuse from the other end of the factory so they could finish of the job being cut. Amp clamped all phases.
Compressor and lots of small bits of kit 36 amps per phase, turn on the laser cutter whish start a filter system first and 60 amps per phase. Laser cutter kicks in and 97 amps per phase. This has been working hard all day from 7.30 am. Can not find any info in the red book on how long a 1361 at say 100 amps will operate for.
My question now being what is the max the DNO will upgrade the incoming fuses to? I have no idea what size the incoming cable is.
Any help from more experienced industrial sparks would be greatfully received.
