DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cutting Baseboards
This topic originated from the How to page called Cutting wood using power tools
Click here to return to the page called Cutting wood using power tools.
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
  View previous topic :: View next topic
Author Message
ret2000army
from United States of America
Thanked: 0 times
PostPosted: Mon Apr 04, 2005 4:17 pm    Post Subject:
Cutting Baseboards
Reply with quote Thanks
Anybody figure out the best way to cut baseboards so they fit neatly and tightly into 90 degree corners? I\\\'m a novice at this and I\\\'m having a hard time not so much cutting the miters, but making sure I\\\'m measuring correctly so the fit is tight.
Appreciate any advice.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Dewy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 12, 2005 11:51 pm    Post Subject:
The reason noone answered you is probably the difference in the language.
The term 'baseboard' is not known here.
It is known as skirting board.
You should be sure the corners are exactly 90° as very few are.
You mitre the outside corners by cutting each piece exactly half of the corner angle.
This could be done either on a hand mitre saw or better on a sliding power mitre saw.
For internal angles you place one piece against the back wall then scribe the mating piece to fit.
Scribing is done by cutting at 45° then using a coping saw to cut along the angle so the blade follows the shape of the moulding.
If you mitred the internal corners the join will open with the wood movement over the seasons.
This doesnt happen with scribed joints.
The opposite applies to outside corners.
Wood movement will close the joint rather than open it so a mitre is the perfect choice.
__________________
Dewy
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Cutting Architrave lengthwise 3 280 Fri Jul 25, 2008 8:43 am
cutting railway sleepers? 4 480 Sun Jul 27, 2008 8:14 am
Kitchen worktop cutting 3 500 Sun Jun 15, 2008 12:21 pm
CUTTING WORKTOP 2 280 Mon Sep 15, 2008 12:45 pm
IKEA kitchen units and cutting them down to size 3 1460 Tue Oct 07, 2008 10:53 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
