showbiz
Joined: 05 Apr 2005 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Tue Apr 05, 2005 3:00 pm Post Subject: Adding an additional spur to an exisiting ring circuit? |
Can anybody with some knowledge please tell me if it possible to add a new spur to and exisiting ring circuit that already has a spur in place. Is it a hazard or will it be ok to wire this up?
Thank you |
mapj1
Joined: 24 Nov 2004 Posts: 1040 Location: United Kingdom Thanked: 0 times
Posted: Tue Apr 05, 2005 3:05 pm Post Subject: |
Its fine so long as you spur off a socket in the middle of the ring, and not from an existing spur, no problems. (unless you ring has more spurs than ring, which is possible, but unlikely).
Better if you can do it neatly to extend the ring, so the new socket is fed from both sides too, but not essential. The biggest no-no is spurs on spurs. __________________ regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs- |
showbiz
Posted: Tue Apr 05, 2005 3:12 pm Post Subject: |
Thanks for your advice. I will look at how the ring is set out before I connect it up.
Thanks |
