DIYnot
Local | Network
   DIYnot > Forums
Local | Network
New hot water cylinder question - hemp or ptfe/compound.....
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
poolebybirth
from United Kingdom
PostPosted: Tue Aug 31, 2010 4:55 pm Reply with quote
FItting a new hot eater cylinder..... woudl you use hemp or ptfe tape and or jointing compound? I know hemp is against water regs though icon_sad.gif - how many turns of ptfe tape is going to be water tight? I usualyl use hawk white (normal not potable, so again against water regs) - anyoen used lsx as jointing compound? any good?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Tue Aug 31, 2010 5:00 pm Reply with quote
12 turns of tape monkeyhanger
Back to top
 Alert Moderators
poolebybirth
from United Kingdom
PostPosted: Tue Aug 31, 2010 5:01 pm Reply with quote
ok cheers kev - 12 turns and hawky white or lsx? i have heard lsx is very good????
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Tue Aug 31, 2010 5:18 pm Reply with quote
Back to top
The following user says thank you to kevplumb for this useful post:
poolebybirth (31 Aug 2010)
 Alert Moderators
poolebybirth
from United Kingdom
PostPosted: Tue Aug 31, 2010 5:21 pm Reply with quote
Got another little thing I'd like to ask your advice on mate..... toilet, siphon diaphragm replaced, all ok, but slight drip form wing nuts ..... doughnut letting by..... anything i can do to stop the drip? as can't get exact doughnut to fit icon_sad.gif
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Tue Aug 31, 2010 5:40 pm Reply with quote
first tighten the big nut
a spot of sealer on the donut wont hurt
Back to top
 Alert Moderators
poolebybirth
from United Kingdom
PostPosted: Tue Aug 31, 2010 5:48 pm Reply with quote
tightened the siphon nut
what sealer on the doughnut? normal siliconer? or lsx?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Tue Aug 31, 2010 6:26 pm Reply with quote
if your using silicone get some dow corning
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Tue Aug 31, 2010 7:02 pm Reply with quote
Loctite 55 - string ptfe stuff, has won a lot of friends. It's MUCH less likely to leak if it's backed off, than tape.
It takes a little practice to know how much to put on but I love the stuff.
Don't be taken in by cheaper lookalikes which are more like narrow thick PTFE. I thnk Todays Tools do one of those - avoid!
It's also good for long screws (- that's a plumbing connection, not a 4 inch 12...)
Back to top
 Alert Moderators
poolebybirth
from United Kingdom
PostPosted: Tue Aug 31, 2010 7:17 pm Reply with quote
kev - what do you mean "dow corning"?!!!
chrisR - I have used loctite tape before worked ok - do you mean use it on te doughnut or on the wingnut? what do you mean when you say "backed off" - sorry fi I sound dumb today icon_smile.gif
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Tue Aug 31, 2010 7:32 pm Reply with quote
Back to top
 Alert Moderators
Threadjacker
from United Kingdom
Thanked: 12 times
PostPosted: Tue Aug 31, 2010 8:00 pm Reply with quote
Dow Corning silicone is probably the best there is, its super smooth, fast curing and sticks like a son of a .......
http://www.screwfix.com/prods/58308/Sealants-Adhesives/Sealants/Sanitary-Sealants/Dow-Corning-785-white
Backed off means when you turn back a fitting, ever fitted an outside tap and it only tightens and the 1 'o clock position? back it off with PTFE and it will probably leak.
Back to top
The following user says thank you to Threadjacker for this useful post:
kevplumb (31 Aug 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Hemp or PTFE? 18 1320 Mon Oct 01, 2007 9:20 pm
hemp on an unvented cylinder 9 720 Fri Mar 28, 2008 10:22 pm
What is plumbers hemp made from? 9 380 Sat Oct 29, 2011 8:33 am
Hemp. 18 620 Mon Jan 24, 2011 10:51 am
Mild Steel unions using hemp and Hawkwhite 18 1100 Thu Apr 06, 2006 10:00 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
