DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Advice on skimming over rough old plaster
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
analhamster
from United Kingdom
PostPosted: Sat Sep 04, 2010 11:54 pm Reply with quote
Hello,
After a bit of practice and a few disasters I can get a nice finish with plasterboard and a skim, for my next project I need to skim over some old plaster. I've removed paper which has left a rough surface, some hollows of variable size, a few holes. There's also a chase which has been filled and stands a little proud. I've knocked off all the loose stuff and sealed with PVA.
My question is, what next? Should I go straight for finish on tacky pva and use a varying thickness with the first layer to smooth the problem areas? Or put a tight coat of bonding round the lot and skim onto that? If bonding, how long should I wait before putting the finish on? Would I need to key it or PVA again?
Basically, how do the pros approach a fairly rough old wall?
Thanks in advance
Back to top
 Alert Moderators
DIYnewbee99
from United Kingdom
Thanked: 114 times
PostPosted: Sun Sep 05, 2010 7:44 am Reply with quote
Not a pro, but in my humble opinion I would approach with the tight coat of bonding route, as you prob have quite a lot of variation. Some may be skilled enough to go straight for the multi to fill out the variation, but for me I would get a better skim finish if I get a uniform bonding thin undercoat first to provide a stable platform ready for the skim.
You've already PVA'd once, so apply more (tacky etc) just before doing the tight coat of Bonding.
then once the Bonding has darkened it can be immediately skimmed requiring no PVA etc.
Skim coat applied in two layers as usual.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Bare rough plaster requiring painting - (I'm a newbie!) 8 580 Sat Jul 03, 2010 11:25 am
Rough cost to plaster a wall after blocking up an opening ? 11 1240 Thu Mar 18, 2010 12:43 pm
Multi Finish Plaster Skim Coated over Rough finish Plaster 5 1500 Sat Jan 09, 2010 6:24 pm
Help for smoothing rough plaster walls & ceiling?! 7 5880 Thu Jul 17, 2003 11:29 am
Rough finish to plaster 2 220 Wed Jan 05, 2011 7:37 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
