Hi- I'd like to have two switches so I can light the entry half of a long room with the first switch, or the whole room with the second one as I enter. Is there a standard layout for this with minimum wiring? Thanks.
And even this would have drawbacks as you would need to make sure you don't have a conflict on the supplies to the relay. As you would have the possibility of 2 supplies to it.
Throw this over the the electronic guys on here, over to you lads
Yes- that's exactly what I'm trying to do. Thanks for this. As it looks quite tricky, and I need to get low voltage downlights anyway (I'm getting latest LED so they're not as dim as a glow-worm), I guess whether there's 10 downlights on or 20 won't make a huge difference to the electricity bill anyway.......
Why not put a 3 position rotary switch on a blanking plate, the positions being OFF, HALF & FULL?
Or use DP switches (may need to use a grid system to get a 2-gang DP) - the FULL switch is the one which needs to be DP, both poles used for live, one to each bank of lights.
