Combi Boiler Pressure Drop
16 Jan 2007
London
hi,any solution (pressure equalisation valve? etc) to fix problem of pressure in shower dropping when any other (say kitchen) tap is simultaneously in use ?
Get a bigger combi. Or get rid altogether and get a system boiler and hot water cyliinder (or Rinnai Twinflow)
Check the mains flow rate against a back pressure of 1 bar BEFORE you spend any money.
No combi or unvented cylinder can heat water faster than the main can supply it!
