Connecting SD1 speech diallar to Scantronic 9751 panel
11 Jun 2010
London
Hello all, I'm not very clear on the trigger connections of the SD1 to a scantronic 9751 panel. I know that the SD1 requires negative trigger to dial out.
I wish to connect the triggers to the fire detector, Panic attack, and a PIR circiut. Do I connect the relevant trigger wires on the SD1 to the circuit connections on the control panel PCB. I understand that the Scantronic panel goes into negative applied upon an alarm condition.
Any guidance appreciated.
regards
