Bosch dishwasher logixx
11 Sep 2010
Hi My Bosch logixx dishwasher doesnt drain the water.Check filters which are clean.How can i access the pump?
Hi
Thanks for your help.The E no is SGS0902GB/05
Kind regards
Take out the filters & bale out as much water as you can from the sump. Look in the left hand side of the sump for a removable plastic cover (it should be fastened by 1 x T20 screw). Removing this gives you access to the pump impellor to fish out any foreign objects, broken glass etc that might be in there. Should you need to remove the pump completely you must take off the access panel directly below the door. Once this is off you will see the pump on the left, it is twist fitted & locked in place by a plastic tag. Release the tag & twist off the pump. You will have more room to work if you take off the outer door first (6 x T20 screws).
Be aware failure to drain can have other causes. Good luck :D
Hi
Thanks for your great advice i'll let you know how i get on!
Thanks Zipper for your help.There was a piece of plastic stopping the impeller from rotating.Thank you very much!
