We have an old open vented central heating system I believe. Water tanks in the loft and airing cupboard, baxi back boiler downstairs in the living room. It's been fine since we moved in (6 month ago), but recently I noticed hot water is much hotter than usual. There is a small regulator next to the water tank in the airing cupboard in our master bedroom which can be turned clock and anticlockwise from 1 to 8, we've always had it set to 2 as that gave us the right temperature, but now whatever I set hot water comes out very hot. BTW heating has been off for all summer and timer is set to heat water for 1 hr in the evening. Would replacing that regulator fix the problem, do we need to drain the system for that, how much would it cost? Appreciate any advice, many thanks.
