B'stards left me and my kids without heating last nite. Tried to strong arm the wife into buying their services.. If I could locate the part I would get a local dude to fix..
not sure what part you need. but they should be available whatever it is. Make a complaint. If your on a contract you've already paid for the repair, so make sure they do it.
They can rot on the top near the pipe exits,usually due to undetected slight water leak at compression fitting or drain cock.If the outer case is perforated then you may well be out of luck.The front cover will not normally require renewal.Have you been on contract long and if so why was this not noticed before it got to this stage?
That is the point 45yearsagasman. Been contract for ages. Seems that they knew a while ago, but chose not to tell us. Yeah, the part we need is indeed obsolete. No one on the planet has one and there are no replacement options..
Doing so at the moment.. Just seems strange that they knew about the problems and obsolete parts, did not tell me, but continued to take my money.. Also I did not memtion the strong arm tactics used to almost black mail the other half into buying from them.. Anyway, rant over I will sort it locally..
