DIYnot
Local | Network
   DIYnot > Forums
Local | Network
BAXI 105HE Boiler Help
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
onlyfools
from United Kingdom
PostPosted: Fri Sep 17, 2010 3:39 pm Reply with quote
Hi everyone
I have a BAXI 105HE Boiler which has stopped heating the hot water when opening the tap, I've had a look and the 50% red light above the fan sign is flashing(when the hot tap is running), the pressure needle says just under 1.
When you turn the tap on you can hear something fire up inside (not being a expert,I don't know what it is). I turned the dial to re-set but still the same.
Any help would be great
Thanks Jane
Back to top
 Alert Moderators
Beerlover
from United Kingdom
Thanked: 210 times
PostPosted: Fri Sep 17, 2010 5:03 pm Reply with quote
I would say it is either your Fan or Air Pressure Switch.The noise you hear is most likely just the pump. I'm informed it might also be the PCB.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi 105he Boiler Pressure 4 820 Wed Feb 14, 2007 10:50 pm
BAXI 105HE CONDENSING BOILER 25 1820 Sat Jan 13, 2007 10:50 pm
Baxi 105he gas boiler 2 60 Mon Feb 20, 2012 1:33 pm
Baxi 105he Combi Boiler hot water preheat issues 3 160 Sun Sep 21, 2014 10:22 pm
Baxi 105HE Combi Boiler Problem - Expansion Vessel? 5 3940 Tue Oct 16, 2012 11:26 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
