Heat Resisting Cable for Underfloor Pump Query
18 Sep 2010
Sussex
The instructions for my Circulating Pumps Ltd pump on my underfloor system say to use 3x0.75 core cable with rubber insulation rated at 110 C. minimum. All the cable I can find though in the suppliers I've looked at is rated at 85/90 C.
Anyone know where I can get higher heat resistant rated cable?
I think you may struggle to find anything in flex that is over 85c.
There are single you can get that are are rated at 110c that are used in commercial catering equipment such as the lights you see above serving counters
link http://shop.bsigroup.com/en/ProductDetail/?pid=000000000030138591
Try getting the 85c butyl type cable and use this
link http://www.tlc-direct.co.uk/Main_In...stant sleeve&gclid=CLef8OmJkaQCFd_-2AodTTPWIQ
Though quite supprised that your pump is recommending such an high temperature cable. In fact if you get the oversleeve you can use normal flex with that as the sleeve can reach 155c
Thanks.
Must say I don't see how the pump could reach much more than the temperature of the water flowing through it. Normally about 40 to 50 C in an underfloor system. The main system pump with 60 C water flowing through it is touchable.
