Have a look at the definition of a spur in the current Regs and post up what you find.Yes. But it won't be a "spur" as that applies to ring finals.
Hi. can you take a spur from a 15A radial using 2.5mm cable? Thanks
my understanding is that the difference between a branch from a radial and a spur from a radial is that a branch has the same rating as the rest of the circuit and can support as many accessories as desired while a spur is lower rated under the same principles and rules as a ring spur.
