Hello all, please can you help with the correct wiring of a 3 pole external isolator switch. Carrying 32a from 10mm armoured cable to power a hot tub.
Inside the switch box are 4 connectors top ( L1 L2 L3), 4 connectors bottom (T1 T2 T3) both top and bottom have 1 connector which I am assuming is switched another way as it shows a switch on the box.
To the left of the connectors are 2 seperate connections showing Earth and N.
I only have the supply in and 1 load out.
Any help would be greatly appreciated.
