The wiring for one of the ring mains for my house has become damaged about a meter above where it exits the fuse box (all circuits exit through top of fuse box and run up the surface of the wall). No electrical damage I just took a chunk out of the insulation while moving some furniture through the garage.
I'm not sure how ring mains are normally terminated, but in our house both the ends of the ring terminate in the fuse box itself. Both cables of the ring have been 'nicked' so I need to replace the first meter of both.
As it happens though, I have a length of 6mm cable spare. Since it can easily carry 32A, is it acceptable to run a single length of this cable the first meter from the fuse box and then crimp connect it to both the cables of the ring main from there?
Cheers,
iep
Cheers,
iep
