Can anyone help!
We have had this boiler for 12 years now. 3 years ago we had the heat exchanger, pump & curcuit board replaced and the whole system power flushed through. This resolved the banging noises and poor rad performance. Since we had that work done, it has worked perfectly but for some reason the boiler will not fire up when we want the heating on.
We last had it on in May and worked fine and the water is heating up as normal when the hot water tap goes on but when we put have tried to put on the heating, it wont work and won't fire up.
We have tried putting the thermostat on full and although it clicks, nothing fires up the boiler. The radiator dial has a red light above it and i wondered if that meant anything.
I would like to try what we can without having to pay someone to come out if possible, so any suggestions are welcomed!
