draining system and using hot water
M
marsaday
Can i drain down my combi and still use the hot water ?
i want to change a few rads and so the heating will be out for 2 days. Still want the hot water though? Will this also be switched off in this case ?
are the isolators for the hot water outlet from the bolier ? would i also close the cold feed isolator ?
heating flow and return if you don't close them before you drain the boiler will lose its pressure
if you close the cold flow you wont get any water :idea:
