Hi New here..
I've just replaced my immersion heater thermostat following a guide on the net - all quite easy, BUT..
the original (old) thermostat had only the live wire connected to it from the pole in the housing- and it worked that way I suppose - until it failed, but the water still got hot, and hotter etc.
I replaced it and wired the new one up the same way, live wire from the pole to the + on the thermostat, and it does not work - no light at the switch. so I connected the neutral pole to the - on the thermostat, and it tripped the circuit breaker.
confused - how does the thermostat interrupt the current anyway wired up like this? and why doesn't it work now??
