worcester 24i junior, no heating, hot water fine
3 Aug 2010
Middlesex
have a 24i junior, hot water working fine but when heating called on a couple of rads get hot then boiler shuts down, flow within a metre of boiler very hot, after a metre and return just warm, any ideas greatly appreciated
Bi thermal heat exchanger, pump works on h/w also! This sounds simply like a circulation prob! Have you got a room stat?
What diameter is your pipework to rads?
Are all valves open?
what is the system pressure?
try bleed the pump and manually turn it to ensure its moving ok, also check pump speed if possible.
It could also be thermistors taking a false reading and cutting heating off before it has had a chance to circulate.. :p
well its one of theses
the pump has gone
primary heat exchanger is scaled
or you have an air lock
finaly your heating pipes are slugged up
