I have a new property and apparently the local water board promised mains pressure at 3 bar but in the event could manage only 2 bar.
So as to make the showers and megaflow system work, the builder installed a water pressure pump in the garage. Consequently each time the showers or taps are run, the pump kicks in once the level in the conatinment chamber (21 litres max) drops below a certain level.
The pump directs pressured water into a pipe that goes up through the garage ceiling to the upstairs taps/showers. Once a certain pressure is reacehd, there is a non reurn valve that cuts in.
the whole process makes the pipes vibrate and shudder with the noise being transmitted into the main "up" pipe and thus into the bedrooms.
All in all not a very good solution as it makes one bedroom almost unusable.
To compound matters, the pump is constantly breaking down resulting in either no pressure or pulsing as it fails to reach pressure.
I'm looking for a suitable consultant or plumbing adviser who can look at the whole system and advise me as to whether the solution I have is the only one available; could it be improved; are other solutions out there?
I have thought about moving the "up" pipe so that it goes through the garage wall, up the outside of the house and into the roof space that way. I worry however about freezing and other damage.
Becoming quite desperate now so any suggetsions welcome.
I live in east Hampshire so local advisers would be better.
