DIYnot
Local | Network
   DIYnot > Forums
Local | Network
which side to fit trv
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
electrospark
from United Kingdom
PostPosted: Sat Oct 02, 2010 12:33 pm Reply with quote
I gather that the trv should be fitted on the flow side of my new towel rail but on my old towel rail it for some reason was fitted to the return side. I will have to alter the pipework to fit it on the flow side so is it acceptable to leave the trv on the return side. Also the reason for me replaceing the towel rail was that it had sprung a leak through the bottom rung me the rail. When I drained it the water was very black and quite a lot of sludge came out. Could this be reason for the corrosion causing the leak? Its a ex council flat which runs from a communal system. Does it require flushing? Thanks
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sat Oct 02, 2010 12:37 pm Reply with quote
as long as the trv is bi directional it won't matter
if your on a district heating system you can't flush yours icon_confused.gif
Back to top
 Alert Moderators
electrospark
from United Kingdom
PostPosted: Sat Oct 02, 2010 2:51 pm Reply with quote
but is it worth trying to get the entire system flushed? Should it not be part of their maitenence procedure?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sat Oct 02, 2010 2:54 pm Reply with quote
in theory yes
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Trying to find an unusual cistern side-lever 3 280 Sun Sep 12, 2010 10:25 pm
Tails wont screw into ONE side of rad tube? 4 220 Wed Sep 29, 2010 1:56 pm
British Gas engineer working "on the side" - cover 59 5880 Sat May 29, 2010 7:58 pm
Wickes slim plastic cistern - side fill to bottom fill? 7 540 Fri Jul 30, 2010 6:54 pm
Radiator side and top? 5 140 Sun Nov 28, 2010 4:33 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
