Hi all,
My hot water supply is not great, its fine if I use the immersion heater but my heating doesn't do much to heat hot water. Its a trade off I know, open the valve on the Hot Water Cylinder and there is more hot water, but less heat in the radiators, and the reverse if I "close" the valve (you never close it completely).
I am installing TRV's on all my radiators soon to better control the heat being delivered to each room. This should in theory make more heat available to the hot water boiler, _but_ the value on the Cylinder is static so the same amount heat is going to make it to Cylinder .
What I really want is system whereby the rooms are heated until they reach their optimal temperature, at which point the TRV's will gradually close off and the valve on the Cylinder will automatically open to allow more hot water into it.
Is this achieveable without spending £1000's
