DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Tips for plasterboarding ceiling
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
ilikewatchingtv
from United Kingdom
Thanked: 3 times
PostPosted: Wed Oct 06, 2010 10:35 am Reply with quote
Hi All,
I'm about to embark on a project to pull down my existing lath and plaster ceiling and replace with plasterboard, prior to having it professionally skimmed.
I plan to use 12.5mm square edged boards, and would be grateful if anyone could advise on the following:
1) Should the boards be laid with the long edge across, or along the joists?
2) Do all edges need supporting? (i.e - will I have to fix noggins between the joists along each unsupported edge?)
3) I've received conflicting info about what length of screw to use - some people have suggested 38mm, some have said not to use anything shorter than 50mm - who's correct?
Thanks for any advice!
Dave.
Back to top
 Alert Moderators
Rusty10
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 06, 2010 11:50 am Reply with quote
Hi
See here http://www.diynot.com/forums/viewtopic.php?p=1680235#1680235 as I answered something similar to this and there is some good info icon_biggrin.gif
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 982 times
PostPosted: Wed Oct 06, 2010 1:18 pm Reply with quote
It is best to do rip it down but a very messy job, sometimes it’s easier just top overboard if it’s not completely falling down.
Yes but use full size boards not small DIY ones; more joints = more chance of cracks.
Yes, board across the joists & stagger the boards to avoid cracks.
As long as your joist spacing is no greater than 450mm & your skimming, it'll be fine. Noggins are recommended for tape & fill but you don't want to be doing that, have it skimmed. Strictly speaking, you should have noggins to support the two unsupported perimeter edges but it should be OK with joist spacing no greater than 450mm.
If it's just 12.5mm PB & into the joists then 38mm is more than sufficient; BG recommend minimum 15mm thread into he joist so 12.5 + 15 = 27.5mm so 38mm is enough, it’s all I use but you can use longer if you feel more comfortable; fix every 150-200mm max.
This is the British Gypsum boarding guide;
http://www.british-gypsum.com/pdf/SB07_Timber%20joist_02.pdf
It’s not working at the moment though as their website seems to be down icon_rolleyes.gif
Back to top
 Alert Moderators
ilikewatchingtv
from United Kingdom
Thanked: 3 times
PostPosted: Thu Oct 07, 2010 4:23 am Reply with quote
Thanks to both of you, - some really good info there, should make the job a lot easier (though sadly won't make it any less messy!)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
tips on plasterboarding a ceiling 7 460 Sat Jan 29, 2011 7:57 pm
Ripdown ceiling and reboard, tips? 4 380 Sat Dec 11, 2010 10:05 pm
Plastering ceiling tips 5 500 Fri Jun 11, 2010 10:20 am
Tips on how to finish boarding curved ceiling. 31 2060 Sat Nov 06, 2010 9:25 pm
Skimming Tips 2 300 Thu Oct 14, 2010 2:37 pm
DIYnot
