DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
loss of pressure
This topic originated from the How to page called Replacing a washer in a tap
Click here to return to the page called Replacing a washer in a tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
joss
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 16, 2005 11:36 am    Post Subject:
loss of pressure
Reply with quote Thanks
I have a monoblock tap in the kitchen. Recently I lost pressure to the cold tap, only got a slow flow, it started leaking and so did the spout. When the tap was turned on the pressure was fine for a second then turned into a trickle and there was a clunk. I changed the valve unit thinking the internal had come apart and were knackered. The new valve unit is doing the same low flow. the rest of the cold taps in the house are fine, Whats happening??? icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
fitz1
from United Kingdom
Thanked: 10 times
PostPosted: Sat Apr 16, 2005 12:01 pm    Post Subject:
sounds like blockage in pipework.
Back to top
 Alert Moderators
corgigazza
from United Kingdom
Thanked: 5 times
PostPosted: Sat Apr 16, 2005 12:07 pm    Post Subject:
Is it mains pressure or fed from cold water storage tank in loft, should be mains pressure so that rules out air lock is the pressure ok on other taps that are fed of the same supplyeg washing machine. other taps may be fed from cws tank, check stop cock
The clonk may be somthing stuck in the pipwork e.g a piece of solder, non return valve fitted
remove pipework and see were good flow is achieved
Back to top
 Alert Moderators
joss
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 17, 2005 2:34 pm    Post Subject:
water pressure is ok in all other taps in house, its mains fed, every now and then we get full pressure coming thro and also sometimes we only get a dribble. We have an isolation valve for this branch and when I adjust it we can get a steady flow if not full but when i turn the valve full on the flow starts messing about and then there's a clunk icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Sun Apr 17, 2005 3:27 pm    Post Subject:
If the tap is fed through a silver flexi pipe it could be kinked or twisted.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sun Apr 17, 2005 3:35 pm    Post Subject:
as corgigazza said it sounds like a check valve
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
joss
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 17, 2005 7:26 pm    Post Subject:
Not too sure where the check valve would be unless its in the monoblock. The only valve, apart from the tap valve, is the in-line isolation valve and i think thats just a normal valve icon_confused.gif icon_confused.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
loss of pressure on central heating 6 620 Mon Nov 19, 2007 9:55 am
loss of pressure in my Worcester oil heatsalve 12/14 7 300 Sat Nov 24, 2007 6:11 pm
leaking rad leading to leaking boiler and loss of pressure 5 240 Tue Nov 27, 2007 8:26 am
Pressure Loss 11 500 Fri Nov 16, 2007 11:36 am
Pressure Loss on Combi Boiler 12 260 Mon May 04, 2009 9:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
