DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Finishing wiring
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
rich.martin
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 16, 2005 12:47 pm    Post Subject:
Finishing wiring
Reply with quote Thanks
I\\\'m hoping someone in this forum has experience of what happens after the wiring is done... I\\\'ve chased out the plaster from floor to ceiling in a channel, put my wiring in capping and am ready to plaster back up. Does anyone know if I should plaster fully up with base coat or do plasterers really leave a couple of mm and skim in the top?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Porker
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 16, 2005 1:01 pm    Post Subject:
I'm not a pro plasterer so if they reply with different advice I would take theirs.
I assume that you have channeled out your wiring runs and have sound skim each side of the channel. Wet the channel and apply a backing coat. I would use browning and rule off with the side of the trowel so it is flush. Then smooth the backing carefully. A small plasterers touching-in tool is good for this. This should bring it slightly below the surface of the surrounding skim. Let this go off a bit until it starts to firm up. Then use the corner of the trowel and bevel the edges so there is about 2mm depth on the edge. Then skim over this. Use a wet brush to keep the new plaster off the existing and you should get a perfect finish.
I only use filler on small repairs as I never get good results on larger areas. I find taking the trouble with some multi finish is always better.
Back to top
 Alert Moderators
rich.martin
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 16, 2005 1:07 pm    Post Subject:
Thanks, that's really useful, I'll give it a go.
Back to top
 Alert Moderators
jbonding
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 16, 2005 6:57 pm    Post Subject:
do like porker says also pva 5-1 up the sides you will find it blends in easier and doesnt suck in straight away, it will also need two coats of paint to cover the pva but its worth it.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Rigid insulation and wiring. 3 140 Sat Nov 14, 2009 4:47 pm
Finishing stud work 3 220 Sun Mar 29, 2009 7:40 am
Finishing concrete slab 9 600 Thu Oct 23, 2008 7:48 pm
finishing off a garden wall 3 280 Sat Sep 20, 2008 7:39 pm
Plastering and finishing corners 5 760 Mon Jan 30, 2006 7:56 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
