DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Problems with halstead ace high combi boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
suemo
from United Kingdom
PostPosted: Fri Oct 08, 2010 10:57 am Reply with quote
Few problems with boiler 9 years old. Hot water doesn't always work. The pin doesn't always come out far enough. Also when i put the heating on it works for a short time then seems to over pressure itself and shuts off. Boiler shuts off until pressure goes down and i press the thermostat reset button underneath. Any ideas please?
Back to top
 Alert Moderators
fazedup71
from United Kingdom
Thanked: 48 times
PostPosted: Fri Oct 08, 2010 11:02 am Reply with quote
sounds like the diaphragm needs replacing, as for the pressure rising that sounds like your expansion vessel either needs recharging or replacing, if you look outside you will probably see water dripping from the pressure relief pipe, if that is the case you will also need to have the pressure relief valve replaced
Back to top
The following user says thank you to fazedup71 for this useful post:
suemo (9 Oct 2010)
 Alert Moderators
suemo
from United Kingdom
PostPosted: Fri Oct 08, 2010 2:23 pm Reply with quote
Thank you thats helpful. Any ideas on cost involved to get someone in? Never had boiler probs before so dont want to get ripped off.
Back to top
 Alert Moderators
ks52
from Unknown or unspecified country
Thanked: 2 times
PostPosted: Fri Oct 08, 2010 10:44 pm Reply with quote
try for a company who does a fixed price repair. There are a few out there
Back to top
The following user says thank you to ks52 for this useful post:
suemo (9 Oct 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
halstead high ace combi - Hot water problems please help :( 14 440 Sun Oct 17, 2010 2:29 pm
Halstead Ace High Combi Boiler - Overheat and Lockout 4 1000 Wed Aug 18, 2010 9:17 am
halstead combi boiler - ace/ace high 3 2684 Mon Apr 24, 2006 10:46 pm
Halstead Ace High Combi Boiler 13 140 Thu Nov 27, 2014 10:41 am
Halstead Ace High Combi Boiler 5 1160 Tue Jan 30, 2007 12:59 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
