Wiring a 2-Gang Light Switch for 2 Separate Lights
9 Oct 2010
Hertfordshire
I am having trouble wiring a replacement 2-gang switch in my kitchen. Any help would be much appreciated!
I need 2 separate lights working independently. Left hand cable (see photo) goes to ceiling lights (red, blue, yellow, earth) and right hand cable goes to under cabinet lighting (red, black, earth).
The 2-gang switch has two banks of L(top) L1 and L2.
What goes where?
This is probably very straightforward - but my fusebox is going trip crazy every time I try!!
Okaaay, but which is the permanent live from the lighting circuit, which is the switched live back to the ceiling light, which is the neutral from the lighting circuit?
You may need to open the ceiling rose to see how the red/yellow/blue are wired.
On the switch the terminals are usually diagonal, ie L on the top matches with L1 and L2 on the bottom. L1 and L2 on the top match with L on the bottom.
So you want permanent live from the lighting circuit to go to L and a short piece of wire linking that to the other L.
One of the L1 is switched live back to the lighting circuit.
Other L1 is switched live to the cabinet light. (Red?)
Presumably you also need to connect the neutral from the lighting circuit to the neutral to the cabinet light. (Black?)
I would imagine that in the three core its red = feed, yellow = switched live and blue = neutral.
In the t&e red = switched live and black = neutral.
feed into common, with a link to the other common.
switched lives into the L1 terminals
Neutrals together in a strip connector
Earths into the earth terminal as per the pic already.
What did you have there before? Was it a 2-gang switch, or a single gang?
Did you think to make a note of how the wires were connected before removing them?
How is it connected there?
Ditto?
What goes where?
Depends what goes where at the other ends of the cables.
Do you have a multimeter?
Do you actually know how lighting circuits work?
//www.diynot.com/wiki/electrics:lighting
Have you got another switch for the ceiling light? Red,Yellow.Blue is normally used for link between 2 way switching, in which case red to L or COM, yellow L1, Blue L2. On the other switch red to L or COM, Black to L1.
However, as you have not noted where they were connected to the old switch no one can be certain without knowing where the Red, Yellow & Blue go to. Time maybe to call an eletrician.
The simplest way to get anywhere is to ask the op to confirm if the black and blue were in a separate connector block.
Since the op told us that various attempts to connect the switch resulted in the 'fusebox going trip crazy' we have to ASSUME the black and blue are neutrals and were together in a separate connector on their own.
If they were in a separate connector block, why were they disconnected?
Thanks one and all for your prompt replies :)
Particular thanks to RF lighting/OwainDIYer - your solution worked perfectly.
The left hand cable contained the permanent live from the ceiling rose.
This was a like for like replacement switch, but my kitchen fitter did not make a note of the previous connections before disconnecting.
However, all good now. Thank you!!!
humble DIYer.
Hi all, apologies for bumping such an old thread. I have the same switch set up as the op except the left switch serves the hall light and the right side serves the porch light. I'm looking to fit a 2 gang smart switch there- I understand what all the wires do but what do I do with the 2 neutral wires? Both into the neutral port?
