I have a Chief KTA325 (http://www.ergodirect.com/product_info.php?products_id=15941) triple monitor mount that I want to mount in the corner of my office onto the wall to free up my desk space. It holds three 26 inch Samsung Monitors that weigh approximately 10kg each and the bracket itself weighs around 10kg - So I have a load of more than 40kg.
If this was just going to be connected to the wall then I guess it would not be too hard but I wish to attach the monitor bracket to the wall in the corner of my office and it will be offset from the wall by about 40cm.
My main concerns are the load on the wall and how best to anchor the setup to the brick walls in my basement office. Should I be using a chemical anchor, rawl bolts, expansion bolts or just standard screws and plugs?
Could I use a plate like this: http://parabolspecialist.dk/shop/vaegbeslag-aluminium-vinkel-702p.html and would it hold 40kg hanging 40 cm from the wall? Or should I use a T&K Bracket? http://www.aerialsandtv.com/_wp_generated/wpd8e1185e_0f.jpg
Any advice appreciated
