| Author |
Message |
tersandra
Joined: 09 Oct 2010 Posts: 3 Location: Cambridgeshire, United Kingdom
Posted: Sat Oct 09, 2010 4:39 pm |
Hi, can anyone help me, my pop up waste is stuck in the down position and I have no idea how to release it. I've tried to look at the back but its a bit tricky. I am a 66 year old woman but I've been a bit of a DIYourselfer for most of my life. Any help would be most appreciated, if not its going to be get a plumber in! |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
swingles
Joined: 08 Oct 2010 Posts: 71 Location: Cheshire, United Kingdom Thanked: 1 time
Posted: Sat Oct 09, 2010 4:46 pm |
Assuming you're talking about a washbasin and not a bath, you may find that using a cup to empty the water out into the bath may reduce the pressure on the plug enough for it to pop up. |
| Back to top |
tersandra
Posted: Sat Oct 09, 2010 5:10 pm |
| swingles wrote: | | Assuming you're talking about a washbasin and not a bath, you may find that using a cup to empty the water out into the bath may reduce the pressure on the plug enough for it to pop up. |
Thanks for that but I've already emptied the washbasin and nothing is happening. I did manage to get the waste up but it just slipped back and is now stuck. I am able to take the whole thing out if it works properly but there's got to be something wrong with the mechanism although it appears to be working correctly. |
| Back to top |
swingles
| Back to top |
wingcoax
Joined: 01 Mar 2009 Posts: 1801 Location: Blackpool, United Kingdom Thanked: 130 times
Posted: Sat Oct 09, 2010 6:02 pm |
It is also possible for the horizontal bar to become offline and miss the plug. Can you get your hand round the back of the pedestal and move the bar by hand? |
| Back to top |
Gees
Joined: 19 Apr 2003 Posts: 846 Location: Durham, United Kingdom Thanked: 9 times
Posted: Sat Oct 09, 2010 6:21 pm |
| tersandra wrote: | | Hi, can anyone help me, my pop up waste is stuck in the down position and I have no idea how to release it. I've tried to look at the back but its a bit tricky. I am a 66 year old woman but I've been a bit of a DIYourselfer for most of my life. Any help would be most appreciated, if not its going to be get a plumber in! |
If you have a shower mat ( the ones with the suction cups underneath ) you can attach one of the suction cups to the waste and pull it upwards at the same time as operating the release. I have a Bathstore pop up in the bath that sometimes needs this treatment, especially if the bath has been really full of water. |
| Back to top |
swingles
| Back to top |
tersandra
Posted: Sun Oct 10, 2010 7:14 am |
Hi, thanks to your great advice swingles and wingcoax the pop up waste is now fixed! It was the screw and I believe it had gone offline and missed the plug as well, screw has been tightened and it all works fine. Thanks so very much, well appreciated! x |
| Back to top |
Gees
Posted: Sun Oct 10, 2010 11:04 am |
| swingles wrote: | Does that actually work gees? Top tip there - I keep meaning to get hold of one of those car valve grinding rubber cup stick thingies!!  |
Yes it most certainly does..  |
| Back to top |
