i am cold
17 Apr 2005
have primatic central heating (cold water tank in loft feeds toilet. mains house. have hot water cylinder in kitchen. potterton gas fire with back boiler. have powerfushed system.individual theromstatic controls on all but bathroom radiator which has none. all radiators work except one in daughters bedroom. when i feel the feed and return pipes connecting to this radiator one is stone cold and the other is very hot. i have replaced some old radiators as they were tatty and have bled all and they seem ok.i have a danfoss pump under the floor.system has been microbore and installed for about 15yrs as it was originally coal central heating which was changed to gas about 8yrs ago so pipe work is original although most radiators have been replaced. i also have a new should be heated towel radiator on bathroom wall which my hubby is terrified to fit as he needs to drain the sytem and is worried about how to do this as he said something about an air bubble. he is superman otherwise and very skilled at most diy. any ideas please. If i can get this solved i will promise to send you a gift.
turn the water off to the head tank in the loft and drain as normal
the problem rad could well be a partial blochage in the pipework
take the rad off and open the valves one at a time into a bucket the one running slow is the prob
possibly a stuck thermostatic valve tho
If its since you did this youve had the problem then an airlock in the system is my #1 suspect.
This advice from Kev covers it well
Tell superman not to fear the bubble!
A quick post with the words 'dirty tap water' and 'primatic' and us plumbers from the planet Klarg will tell you how to restore your kryptonite air bubble.
No gift required
Kev the system has a primatic, so no header tank.
Circulation problem most likely introduced when valves replaced. Was the installation commissioned for temperature drop across the rads?
