DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Best power shower method from Combi boiler
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Fixitrite
from United Kingdom
Thanked: 4 times
PostPosted: Wed Oct 13, 2010 11:45 am Reply with quote
Hi
Please excuse me if this has been asked 1000 times before, did a search but didn't find anyting on Wiki.
There are 4 of us in the house ( bungalow ), shower room and separate bathroom but bath is very seldom used, family use the shower in the morning.
I currently have a combi boiler and electric shower. I'm going to re fit the shower room and want to fit a shower with some decent pressure behind it.
What is the best method to get good water flow , do I have to fit a hot water tank in my loft ?
Thanks.
Kenny.
Back to top
The following user says thank you to Fixitrite for this useful post:
potterballs (12 Mar 2011)
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Wed Oct 13, 2010 11:58 am Reply with quote
depending on water pressure /flowrate
you can run a mixer shower direct from a combi
other option is storage tank / hot water cylinder connected to the combi on a "s" plan and a shower booster pump icon_idea.gif
Back to top
The following user says thank you to kevplumb for this useful post:
 Alert Moderators
Fixitrite
from United Kingdom
Thanked: 4 times
PostPosted: Wed Oct 13, 2010 5:10 pm Reply with quote
Thanks Kevplumb
But what do I need to do to give me a power type shower from a combi boiler ?
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Wed Oct 13, 2010 6:02 pm Reply with quote
Back to top
 Alert Moderators
mysteryman
from United Kingdom
Thanked: 233 times
PostPosted: Wed Oct 13, 2010 7:06 pm Reply with quote
I have to disagree. As long as you have a good mains water supply, a combi with a good combi-compatible shower will give you all you need, with far less complication.
Back to top
The following user says thank you to mysteryman for this useful post:
 Alert Moderators
Fixitrite
from United Kingdom
Thanked: 4 times
PostPosted: Wed Oct 13, 2010 8:39 pm Reply with quote
Thanks guys.
I think what I'll do is fit a temp rubber shower head to my bath mixer tap and see what the flow is like.
Back to top
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Wed Oct 13, 2010 9:17 pm Reply with quote
Back to top
 Alert Moderators
ianniann
from United Kingdom
Thanked: 74 times
PostPosted: Wed Oct 13, 2010 9:31 pm Reply with quote
Nobody seems to have addressed the question which is being asked, which is about fitting a power shower to a combi. The answer, and I think most people will agree, is that you don't and you can't. Water from a combi is (should be) at a good mains oressure and will produce a good shower through a simple mixer or more complex balanced or thermostatic shower. Adding a pump to drag hot water directly from a combi is a thing not to be contemplated lightly.
Your description implies further questions. You might want to run two showers at once. Is your combi powerful enough? Is your mains pressure and flow rate good enough? Are you prepared for the expense and trouble of fitting a supplementary tank and pump to provide enough water for two showers and maybe taps too? You might want to sit tight with your electric, pathetic though it may be.
Back to top
The following 2 users say thank you to ianniann for this useful post:
potterballs (12 Mar 2011), Fixitrite (14 Oct 2010)
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Wed Oct 13, 2010 10:41 pm Reply with quote
err who mentioned fitting a power shower to a combi directly icon_question.gif icon_question.gif icon_question.gif
Back to top
 Alert Moderators
Fixitrite
from United Kingdom
Thanked: 4 times
PostPosted: Thu Oct 14, 2010 11:05 am Reply with quote
So, if I go down the fitting of a tank, what is the simplest method of getting a system .
Is it a hot water tank with electric immersion coil with a pump supplying the shower mixer valve ?
I wont be running two showers at the same time, nor a bath and shower but someone could run the hot tap in the kitchen when shower is on.
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Thu Oct 14, 2010 9:55 pm Reply with quote
Hang on we all seem to be getting confused here. You should be able to run a shower mixer direct off your combi. Get a combi-compatible mixer, no need to go to all the trouble and expense of a hot water cylinder and pump unless your mains pressure is absolutely carp
Back to top
The following user says thank you to muggles for this useful post:
 Alert Moderators
kevplumb
Thanked: 916 times
PostPosted: Thu Oct 14, 2010 10:01 pm Reply with quote
Back to top
The following 2 users say thank you to kevplumb for this useful post:
potterballs (12 Mar 2011), Fixitrite (15 Oct 2010)
 Alert Moderators
potterballs
from United Kingdom
PostPosted: Fri Mar 11, 2011 8:43 pm Reply with quote
i am just putting in a new bathroom and am looking at the pod type shower with the body jets and putting in a combi , however i want the shower to be quite powerful so what do you recon? i like the pod idea but i want a powerful shower like you get in a hotel
Back to top
 Alert Moderators
ironman1
from United Kingdom
Thanked: 27 times
PostPosted: Fri Mar 11, 2011 8:58 pm Reply with quote
Unvented hot water cylinder is a good way to go , if mains pressure is an issue then a break tank can be used to boost pressure...................any combi will struggle to supply the demand you're after , Vaillant 937 included. icon_wink.gif
Most domestic dwellings will require a 32mm main in order to cope with these type situations.
Back to top
The following user says thank you to ironman1 for this useful post:
 Alert Moderators
potterballs
from United Kingdom
PostPosted: Fri Mar 11, 2011 9:32 pm Reply with quote
when i had the idea of putting in a new bathroom i was excited! now not so much! here is a spin off from origonal question, i realy like the pod with the steam and the body jets , however i do want a powerful shower, and i want to put rads in the upstairs rooms in the house (i have no central heating at min) abd i wanted to get rid of the cylinder cupboard in bath room, now half of what i want requires a combi and half requires a cylinder with a pump if im not mistaken? now unfortunately i dont have brandsons wallet and i havent got a clue about plumbing as you can probably tell so here is the biggie.....
WHAT DO I DO??
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Best method to measure boiler flow and return ? ? ? 5 760 Tue Dec 22, 2009 6:11 pm
Communication method between boiler and wall unit. 8 420 Fri Jul 23, 2010 5:52 am
correct method of installing a strap on boss? 7 260 Wed Feb 16, 2011 12:26 am
Systematic method for locating CH leaks? 4 300 Wed Oct 06, 2010 10:34 pm
Order of work/method for plumbing/fitting a Belfast sink 2 160 Sun Apr 24, 2011 9:15 pm
DIYnot
