DIYnot
Local | Network
   DIYnot > Forums
Local | Network
adding inhibitor to combi boiler - Worcester Bosch
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gregst
from United Kingdom
PostPosted: Wed Oct 13, 2010 8:13 pm Reply with quote
I am replacing a radiator for a higher btu rated one. But have noticed that the old water was showing signs of rust contamination. I want to add inhibitor to the system but not sure how to. I have a Worcester Bosch combi boiler. Any suggestions please.
Back to top
 Alert Moderators
onlyfitidealboilers
from United Kingdom
Thanked: 151 times
PostPosted: Wed Oct 13, 2010 8:18 pm Reply with quote
Back to top
The following user says thank you to onlyfitidealboilers for this useful post:
gregst (13 Oct 2010)
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1500 times
PostPosted: Wed Oct 13, 2010 8:22 pm Reply with quote
...it will be easier if you remove the plug that the air vent needle screws into, or the plug on the other side. Then with a funnel and a bit of hose pour it in through the top. This is after you have fitted the rad to the valves, but before you have opened the valves to let it fill with water.
If you have drained the systemn, you can pour it down one of the pipes that the rad valves go onto (assuming they run downwards).
Back to top
The following user says thank you to JohnD for this useful post:
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Adding inhibitor to my combi boiler filling loop? 2 2300 Sun Feb 03, 2008 6:02 am
tips for adding inhibitor to combi system 14 1720 Tue Dec 07, 2004 8:14 am
Adding corrosion inhibitor to a heating system 2 1340 Sat Nov 04, 2006 2:26 pm
Adding inhibitor to sealed system 3 480 Mon Nov 03, 2008 7:14 pm
Adding Inhibitor - have I screwed up? 3 300 Thu Nov 13, 2008 8:30 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
