My doors are fitted with locks that use a key looking simillar to a yale key and the door handle has to be pushed upwards before you can lock the door.
I am told that the locks can be broken from the outside removed and the door opened with a screwdriver.
I am also informed that there is a type that has a weaker point built in so that they snap off and do not allow the use of the screwdriver.
Is this correct and if so how do I tell the differance between the two types.
Thanks in advance.
Thanks in advance.
