I've just had the electrical second fix completed by my electrician for our loft conversion. Before leaving he did a number of tests on the new upstairs circuit. The circuit is a radial with 5 double sockets, the floor area is approximately 35m2. The electrician left and I assumed all was okay and that I would get an electrical certifiacte for submission to building control ahead of getting a completion certificate. I phoned the electrician to discuss payment and he (the boss of the younger guy who did the work) told me that the guy who did the tests said that he in not comfortable signing an electrical certificate because some of the test readings cause him concern. He said that when testing the rcd protected circuit his meter would sometimes read very few ohms and then when he would re-test it would read high numbers of ohms. I not quite sure what this means, he later checked his equipment and says that it is functioning normally. Can anyone tell me what the possible/ probable causes may be for fluctuating readings when testing the circuit?
Many thanks.
Many thanks.
