Telephone cable demarkation
18 Oct 2010
I've read quite a bit about how much of the telephone line BT own, some people have said if there's a problem with the cable in your property then they will charge for repairs and others have said that the cable is BT's up until the master socket box. Can anyone clarify this?
and does previous owners of the property moving the cable muddy the waters any?
BT own all wiring up to the NTE. if it is faulty through normal wear and tear they will replace with no charge. if it goes faulty by it being damaged or moved by a non-BT engineer then you will be charged to fix it.
you could try saying it was the previous owner but it would still have been adjusted without their consent and you could be charged
Correct; strictly speaking it's also illegal to move or change it & they can get very stroppy about it if they choose to.
If it's dodgy extension wiring the other side of the master socket that's causing problems then probably but not always.
Not really; they may take sympathy on you & maybe not!
What's the problem anyway, telephone extension wiring is hardly rocket science!
our dial tone is either none existant or very noisy. A BT engineer has been out and replaced one taped up section of cable going into the master socket but reported it as 'fault not found' to Orange (our supplier). I'm assuming there's another break in the cable; it's not been chased into the wall and it's not actually held down on top of the door frame
In BT / Openreach language, FNF (Fault Not Found) acknowledges there is a fault, but it is somewhere outside the engineers remit to repair. Maybe it's inside an exchange, or requires input from another part of BT or another supplier (Orange?) to remedy it. The fault report remains 'live', with someone other than the original engineer it was assigned to working on it.
The alternative, RWT (Reported without Trace) would have meant the line was functioning correctly when the engineer visited, with no further action required, and the fault report closed.
So it looks like the engineer has passed the fault report on to Orange to deal with it.
thanks everyone, I'm sure the engineer said fault not found though he could have said the other. My broadband is also off which suggests that both wires in the cable are severed or not connected properly. Also, everything is run from the test socket in the master, there wasn't a cover on the master box when we bought the house and the master is right next to a radiator; but that hasn't made much difference for the last two years
RWT - (right when tested) can only be used if no faulty line tests have been stored and charges will apply. FNF -(fault not found) on the day but has tested faulty can still be closed off.The fault only remains live if the engineer does not sign it off.
