DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to test boiler fan?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
babaton
from United Kingdom
PostPosted: Mon Oct 18, 2010 3:17 pm Reply with quote
Hi, This is my first post, I'm hoping some of you guys can help me....
My boiler has just gone on the blink.
It just stopped lighting and it makes a loud whirring noise. I removed the cover and I can see the fan isn't spinning.
So , I tried to spin the fan with my hand and it's really stiff, "the bearings" I thought. Removed the fan but once it's removed the fan moves freely.
If I turn on the boiler without the fan connected there's no whirring but of course the boiler doesn't light.
So, can I test the fan? I just want to put a current across it and see what it's doing but I'm not sure about the best way to do that.
Is it possible for the motor to be **** in such a way that when it's on it'll try to alternately spin one way and then the other? resulting in a loud whirring and no movement?
I'm really hoping it's just the fan as they are only 40 on ebay....
HELP!
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 947 times
PostPosted: Mon Oct 18, 2010 4:36 pm Reply with quote
What make & Model Boiler do you have some boilers have D.C. Fans others are 230VAC sounds like the fan motor has had it with a knackered shaded pole motor the fan will spin freely untill power is applied it then locks up new motor should sort it by the way you should not be changing this yourself as it is classed as Gas work and leagally you have to carry out specialist tests on completing the work to ensure that the boiler is safe and not spilling Carbon Monoxide into your home
Get in a pro to do this work for you and be wary of non original parts sold on E-bay you could invalidate any warranty and infringe gas safety regulations icon_wink.gif
Back to top
 Alert Moderators
babaton
from United Kingdom
PostPosted: Mon Oct 18, 2010 4:55 pm Reply with quote
It's a potterton profile 80.
I didn't think I'd need to worry about getting an engineer as I'm not going near the actual gas.
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3207 times
PostPosted: Mon Oct 18, 2010 5:00 pm Reply with quote
the fan affects combustion as could your actions, IT IS GAS WORK. You should be engaging an RGI for this work.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Mon Oct 18, 2010 5:02 pm Reply with quote
Back to top
 Alert Moderators
mrgas
from United Kingdom
Thanked: 239 times
PostPosted: Mon Oct 18, 2010 5:27 pm Reply with quote
You have already got too 'close to the gas'.
Best advice I can give is get yourself a Gas Safe person round.
Dont buy any boiler components from ebay.
Switch the mains off to your system and leave it off until a gas safe person has repaired it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Electrical test procedure on gas boiler advice 11 260 Tue May 20, 2014 9:12 pm
Spillage test on back boiler 59 6440 Sat Jan 26, 2008 6:57 pm
Boiler not lighting - test results look odd. 13 240 Fri Mar 07, 2014 1:02 pm
transco test 3 260 Thu Sep 09, 2010 4:18 pm
System test and new concrete. 6 240 Mon Aug 16, 2010 6:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
