central heating problem
19 Oct 2010
Middlesex
i have added extra rad to ch system refilled system,or so i thought but turned on started to get warm went off then on again after a while pump got hot &very noisy as if no water going through bled rads but no9 air or water seems to be coming out help me :cry: :cry:
bleed the pump
does the pump sound noisey ?
is it an open vented system ?
turn the system off.
hold a rag under the centre screw and remove screw.
it'll trickle some water out and also remove air.
fit the screw turn pump up to speed 3 and try again.
pipe either side of pump should get hot.
make sure you try heating and hw so all air is removed.
have you any bleed vents around the flow pipe into the cylinder etc ?
img]        thanks for your help iwill try that tomorrow had enough for tonight
