Worcester Bosch DT10rf
19 Oct 2010
Sussex
Having read thru' the WB installation guide (still undecided about buying) I can't find any mention of removing the link at the ST10 (where the room thermostat is connected). Should the link be removed if the DT10rf is installed?
Hi, I've just bought the DT10RF. I'm pretty sure I've installed it correctly and as recommended here I've left the wired thermostat wired into ST10. However it would seem that my boiler is still taking commands from the wired thermostat and not the the wireless one. Am I missing something?
Thanks, Daniel
remove all wires from old stat at the boiler end etc. Place a link between LS and LR. away you go! the old stat is NOT a link.
Thanks for getting back to me boilerdoktor.
So just so I'm clear (really paranoid about blowing the PCB), I remove the connections on ST10 on the boiler and then add the link which I suspect is a U shaped piece of metal between LS and LR?
Where would I get this link from?
Thanks again, Daniel
There may be a u-shaped piece of metal available, but a "link" is any appropriately rated piece of wire.
