Hi
I have a strange issue with my central heating that I cannot figure out nor can the last 3 Central Heating engineers I've tried.
My system is quite basic. Firstly it's microbore, it has a condensing boiler feeding a pump in the airing cupboard upstairs that splits into 2 feed and returns which in turn split into manifolds with 4 rads at the back of the house and 5 at the front. the system also has a header tank and a vent pipe into the water tank in the loft but the problem is this.
When it's starts up it will run for about 15 minutes with no issue and quite quietly. After about 15 minutes the noise starts, it sounds like air running through the pump, the pump becomes very noisy to the point we can't hear the TV in the lounge. It does this everytime we use it either hot water, central heating or both.
We cannot find any where air is getting in, we cannot find any air to bleed out of rads or otherwise, we cannot find any cause of this at all but it is a real problem as when the heating comes on in the morning it will eventually wake us up. Also it is worth noting it will then start cycling this noise with about a 2 minute break in between
Any help will be greatly apreciated as I said before severl heating engineers have tried and failed
