DIYnot
Local | Network
   DIYnot > Forums
Local | Network
worktop joints
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
jime17
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 20, 2010 9:16 pm Reply with quote
evening all.
I am looking to create a rather long worktop run using 38mm thick, 600mm deep laminate worktop.
Its going to be in excess of the maximum length this particular worktop comes in.
My question is, how would you guys suggest I join the two lengths?
A male/female scribed joint using a worktop jig and worktop bolts as you would do in the corners? or just butt the two straight edges together and use worktop bolts?
thanks in advance.
jim
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 944 times
PostPosted: Wed Oct 20, 2010 9:28 pm Reply with quote
you need to cut off any unfinished worktop[without laminate ]then use a router and worktop bolts or risk a drill and chisel
Back to top
 Alert Moderators
jime17
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 21, 2010 7:54 am Reply with quote
Thanks Al,
Should I just cut the two ends straight and butt them together? or use the jig to create male and female cutouts along the two edges to be joined?
I'll use a router to cut out the slits for the worktop bolts.
Back to top
 Alert Moderators
pompeyal
from United Kingdom
Thanked: 26 times
PostPosted: Thu Oct 21, 2010 11:15 am Reply with quote
I would cut the ends straight then using a decent router machine a good edge on each, be carefull that you cut into the rolled face of the worktop in the right manor for each or else the cutter will break out the laminate. Once that has been done using a biscuit cutter cut out the slots to fit biscuits, then using a worktop jig cut out the fixing bolt slots, apply worktop adhesive to the joints, fit the biscuits and then join together with the bolts....job done
Back to top
 Alert Moderators
jime17
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 21, 2010 12:00 pm Reply with quote
thanks guys
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Location of worktop joints 19 5000 Sat Jun 16, 2007 10:23 am
Wooden stave kitchen worktop joints 7 1560 Sat Dec 03, 2005 5:30 pm
Solid wood worktop - butt joints - correct sealer/glue? 3 1280 Sat Apr 18, 2009 6:25 pm
kitchen worktop joints? 5 1240 Sun May 20, 2007 10:40 am
Seal worktop joints - PVA? 4 700 Sat Jun 05, 2010 8:25 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
