Hi guys, hope someone can advise me on the following problem.
My downstairs hallway rad, which is furthest from the pump, struggles to get really hot, it gets hot at the top but only warm at the bottom. I don't think it's sludge as all rads are only a couple of years old and the system was drained very recently.
I think the circulation may be poor as I have balanced the system as best I can and all other rad lockshields are only open ¼ to ½ turn to get the hallway rad hot at the top. This then makes all the other rads only warm at the bottom, but if I open their lockshields a bit they get very hot at the bottom, so it’s almost as if I’m starving them too much to get the hallway a bit hotter.
Let me explain the setup. It’s an open vented system in a 3 bed semi that has 2 floor levels and a loft. The boiler is a potterton suprima 60 which is in 1 bedroom upstairs. In the airing cupboard on the upstairs landing is the storage tank, 3 way valve and grundfos 15-50 pump. Now this part is where I am thinking the problem may be but i am not sure, the flow and return pipes for the boiler are going up into the loft, across and then down into the airing cupboard to the pump, will this affect the pump performance with the pipes being in the loft with regard to the pump head being 5 metres? The height from lowest downstairs pipes to the flow & return in loft is about 5.1 metres but from the pump to the loft is only about 2.5 metres, which measurement is to be used for head calculation?
Also the downstairs is solid floor so there are 3 separate pipe runs down to the rads downstairs that have to be pumped back up, I am wondering if all this is too much for the pump, any ideas?
