ferroli combi boiler problems
24 Oct 2010
Flintshire
have a ferroli domina 80 combi and have been having problems with it ever since moving in 3 years ago. It seems to be worse in the winter months. I can run the heating for a while and it works fine but once system is hot after running for an hour or so it keeps failing to fire up and gives up even trying, very annoying when trying to have a shower. during colder months it struggles right from the start and burner goes out as if there is not enough gas getting through.
have spoken to a couple of plumbers and they just say it will be trial and error to find faulty part and could cost a lot. so hoping somebody could help me.
Might be worth giving national grid a ring on 0800 111 999 and having the meter/govenor checked out before calling a RGI,
gaz, not sure what venturi`s are????
picasso, can they check gas pressure coming in to the boiler? do they charge?
do you have any idea why it it so much worse when its cold weather, the gas supply is run externally around the house from meter to boiler, is it possible that cold conditions could be affecting the pipe somehow?
Did the previous owners have this problem? when was it last serviced?,out of interest, what size is the gas pipe?. thanks.
not sure about previous owners, we have always had the issue since we moved in though. we had it serviced last year. gas pipe is 22mm i think
nat grid will check the meter for free, if it isint the meter or govenor at least you have ruled it out.
