Switch fuse...rcd?
S
scotteng
hello people.
I need to install a mini fuse box at a location away from the main supply. So ill be adding a switch fuse. The new fuse box will be incorperating rcd protection, the cable supplying the new box will be partially embedded in a wall so will need to be rcd protected.
my question is should i just have one rcd with the swtich fuse or another in the new box?
thanks
It not about being good. It's about having enough knowledge and experience to carry out a job safely.
